PreviousNextJavaScript must be enabled to correctly display this content
H.323 Admission Control Configuration
You can configure the endpoint to allow accept and process requests from a H.323 realm. If a request does not meet the criteria you set here, it is rejected.
To configure admission control:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
h323
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# h323ORACLE(h323)#
Type
h323-stacks
ORACLE(h323)# h323-stacksORACLE(h323-stack)#
Set the criteria upon which you want to base admission control.
allow-anonymous—Enter the anonymous connection option (mode) you want applied to the processing of H.323 requests. The default value is all.
The following are valid values:
all—No ACL is applied and all anonymous connections are allowed.
agents-only—Only requests from configured session agents are processed.
realm-prefix—Only requests from session agents and addresses matching the realm’s address prefix are processed. All other requests are rejected.
The following example shows the
allow-anonymous parameter has been configured to allow only requests from configured session agents. All other
h.323-stack parameters are omitted for brevity.
