Using the Timezone-Set Wizard
You can configure the timezone on the Oracle® Enterprise Session Border Controller (E-SBC) by running a timezone-set wizard from the root location from the ACLI. Use the following procedure to configure the E-SBC time zone. If you need to exit the timezone-set command before completing it, use the key sequence Ctrl-D.
The following procedure may display different prompts depending on whether your system is running on VXWorks or LINUX.To configure the time zone:
At the root prompt,
enter
timezone-set, and press Enter.
ORACLE# timezone-set
The E-SBC displays the following:
========================================== Calling tzselect. Use ^D to cancel without save Please identify a location so that time zone rules can be set correctly. Please select a continent or ocean. 1) Africa 2) Americas 3) Antarctica 4) Arctic Ocean 5) Asia 6) Atlantic Ocean 7) Australia 8) Europe 9) Indian Ocean 10) Pacific Ocean 11) none - I want to specify the time zone using the Posix TZ format. #? ==========================================
Enter the number corresponding to the
continent or ocean you want to select,
, and press Enter. Or, enter
none to specify the
time zone using the Portable Operating System Interface (POSIX) time zone
format.
For a procedure to configure time zones using POSIX format, see Configuring Timezone using POSIX Format.#? 2The E-SBC displays the following:
========================================== Please select a country. 1) Anguilla 2) Antigua & Barbuda 3) Argentina 4) Aruba 5) Bahamas 6) Barbados 7) Belize 8) Bolivia 9) Bonaire Sint Eustatius & Saba 10) Brazil 11) Canada 12) Cayman Islands 13) Chile 14) Colombia 15) Costa Rica 16) Cuba 17) Curacao 18) Dominica 19) Dominican Republic 20) Ecuador 21) El Salvador 22) French Guiana 23) Greenland 24) Grenada 25) Guadeloupe 26) Guatemala 27) Guyana 28) Haiti 29) Honduras 30) Jamaica 31) Martinique 32) Mexico 33) Montserrat 34) Nicaragua 35) Panama 36) Paraguay 37) Peru 38) Puerto Rico 39) Sint Maarten 40) St Barthelemy 41) St Kitts & Nevis 42) St Lucia 43) St Martin (French part) 44) St Pierre & Miquelon 45) St Vincent 46) Suriname 47) Trinidad & Tobago 48) Turks & Caicos Is 49) United States 50) Uruguay 51) Venezuela 52) Virgin Islands (UK) 53) Virgin Islands (US) #? ==========================================
country you want to select
, and press Enter.
#? 49The E-SBC displays the following:
========================================== Please select one of the following time zone regions. 1) Eastern Time 2) Eastern Time - Michigan - most locations 3) Eastern Time - Kentucky - Louisville area 4) Eastern Time - Kentucky - Wayne County 5) Eastern Time - Indiana - most locations 6) Eastern Time - Indiana - Daviess, Dubois, Knox & Martin Counties 7) Eastern Time - Indiana - Pulaski County 8) Eastern Time - Indiana - Crawford County 9) Eastern Time - Indiana - Pike County 10) Eastern Time - Indiana - Switzerland County 11) Central Time 12) Central Time - Indiana - Perry County 13) Central Time - Indiana - Starke County 14) Central Time - Michigan - Dickinson, Gogebic, Iron & Menominee Counties 15) Central Time - North Dakota - Oliver County 16) Central Time - North Dakota - Morton County (except Mandan area) 17) Central Time - North Dakota - Mercer County 18) Mountain Time 19) Mountain Time - south Idaho & east Oregon 20) Mountain Time - Navajo 21) Mountain Standard Time - Arizona 22) Pacific Time 23) Alaska Time 24) Alaska Time - Alaska panhandle 25) Alaska Time - southeast Alaska panhandle 26) Alaska Time - Alaska panhandle neck 27) Alaska Time - west Alaska 28) Aleutian Islands 29) Metlakatla Time - Annette Island 30) Hawaii #? ==========================================
time zone region you want to select
, and press Enter.
#? 1The E-SBC displays the following:
========================================== The following information has been given: United States Eastern Time Therefore TZ='America/New_York' will be used. Local time is now: Wed Mar 13 11:18:52 EDT 2013. Universal Time is now: Wed Mar 13 15:18:52 UTC 2013. Is the above information OK? 1) Yes 2) No #? ========================================== -
Enter
1
(Yes), and press Enter. Or, enter
2
(No) to go back to Step 2 and enter the correct time zone
information.
========================================== Timezone=America/New_York ORACLE# ==========================================
