Configuring Timezone using POSIX Format
If you want to configure the timezone using POSIX format, you can select the option none - I want to specify the time zone using the Posix TZ format. in Step 2 of the timezone-set wizard.
If you need to exit the timezone-set command before completing it, use the key sequence Ctrl-D.To set the timezone using POSIX format:
