Configuring Rate Constraints for Session Agents
You can also use this feature for individual SIP session agents.
To configure rate constraints for a SIP session agent:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-agent
and press Enter.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
If you are adding rate constraints to an existing configuration, then you will need to select the configuration you want to edit.
Type
rate-constraints and press Enter.
ORACLE(session-agent)# rate-constraints ORACLE(rate-constraints)#
method—Enter the SIP method name for the method you want to throttle. Your entries should come only from the following list:
NOTIFY
OPTIONS
MESSAGE
PUBLISH
REGISTER
- max-inbound-burst-rate—For the SIP method you set in the methods parameter, enter the number to restrict the inbound burst rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
- max-outbound-burst-rate—For the SIP method you set in the methods parameter, enter the number to restrict the outbound burst rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
- max-inbound-sustain-rate—For the SIP method you set in the methods parameter, enter the number to restrict the inbound sustain rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
- max-outbound-sustain-rate—For the SIP method you set in the methods parameter, enter the number to restrict the outbound sustain rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
- Save and activate your configuration.
