If you are adding this feature to an existing configuration, then you will need to select the configuration you want to edit.
constraint-name—Enter the name of the session constraint configuration where you have set up rate constraints to apply them to this SIP interface. This parameter has no default, and must be the valid name of a session constraint configuration.
