Rate Constraints for SIP Interfaces
To apply rate constraints to SIP interfaces, you need to configure rate constraints in the session constraints configuration and then apply the session constraints to the SIP interface where you want them used.
Note that you need to set up the parent session-constraint configuration to save any rate constraints you configure.
To configure rate constraints:
