SIP Request Method Throttling Configuration
This section shows you how to set up rate constraints for session constraints (which are then applied to SIP interfaces) and session agents.
To use this feature, you must enable the extra-method-stats parameter in the global SIP configuration.
To set the extra-method-stats parameter in the global SIP configuration:
