How Whitelists Work
Whitelists allow you to customize which SIP signaling messages to allow into your network and which messages to reject or delete. In the flow of SIP traffic to/from the Oracle® Enterprise Session Border Controller, the Oracle® Enterprise Session Border Controller matches any received request or response, in or out of a dialog against the configured allowed list, and rejects or deletes the non-matching element based on the actions specified in the whitelist configuration.
For responses, the Oracle® Enterprise Session Border Controller does not reject the message if a header or parameter is not found in the allowed list, even if the action is set to reject. Instead it deletes the offending parameter or header. In addition, if the message is a request of the method type ACK, PRACK, CANCEL or BYE, it deletes all unmatched elements, but does not reject the request, even if the action was configured to reject.
The whitelist verification performs for any method; however you can narrow this list to operate only on specific methods by defining them in the methods parameter of the configuration.
Whitelist verification occurs when a request or response is received by the Oracle® Enterprise Session Border Controller, but only after the Oracle® Enterprise Session Border Controller has processed the inbound header manipulation rule (HMR), network management controls (NMC), Resource-Priority header (RPH), and monthly-minutes checking.
The Oracle® Enterprise Session Border Controller responds to requests which have non-matching headers or parameters configured with an action of reject, with a "403 Forbidden" response by default. You can use a local-response event, allowed-elements-profile-rejection, to override the default reject status code and reason phrase.
The configured whitelist operates transparently on headers that have multiple URIs or multiple header values within a single header (header values separated by a comma).
Parameter parsing operates only on parameters that it can identify. For parameters that can not be parsed, for example an invalid URI (e.g. <sip:user@host.com&hp=val>), the Oracle® Enterprise Session Border Controller ignores this URI header parameter value of "hp" since it is not contained within a valid URI. Even though it would appear to be a URI header parameter, URI headers must come after URI parameters. Parameter matching does not occur if the headers and parameters in the URI are not well-formed. The Oracle® Enterprise Session Border Controller does not remove the parameter since it cannot identify it.
