Verify Whitelist Configuration
After you have configured and saved a whitelist on the Oracle® Enterprise Session Border Controller, you can use the existing verify-config command at the top level prompt to verify the saved configuration: For example:
ORACLE# verify-config
This command checks for errors in the Oracle® Enterprise Session Border Controller configuration. Whitelist configuration errors specifically related to the enforcement-profile object also display in the output of this command if applicable. The whitelist configuration errors display if any references to the allowed-element-profiles are improperly configured. If errors exist, the following message displays:
--------------------------------------------------------------------- ERROR: enforcement-profile [ep] contains a reference to an allowed-enforcement-profile [abc] that does not exist ---------------------------------------------------------------------
