Bandwidth Sharing Configuration
To enable bandwidth sharing of forked calls, set the forked-cac-bw parameter in the SIP profile configuration to shared. Although there are other parameters available in the SIP profile configuration, you only have to set the name and the forked-cac-bw values to use this feature.
After you set up the SIP profile, you apply it to a realm, SIP interface, or session agent.
