Configuring a SIP Profile
The SIP profile is an element in the ACLI’s session-router path, and you can configure multiple SIP profiles.
To configure a SIP profile:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-profile
and press Enter.
ORACLE(session-router)# sip-profile ORACLE(sip-profile)#
- name—Enter a name for this SIP profile configuration. This parameter is blank by default, and it is required. You will need the SIP profile’s name when you want to apply this profile to a realm, SIP interface, or SIP session agent.
forked-cac-bw—Set this parameter to
shared if you want forked sessions to share bandwidth resources, or set it to
per-session if you want bandwidth to be counted for each session individually. There is no default for this parameter, and leaving it blank means:
For an ingress session agent without a SIP profile or with a SIP profile where the forked CAC mode is blank, the Oracle® Enterprise Session Border Controller will reference the associated realm.
For an ingress realm without a SIP profile or with a SIP profile where the forked CAC mode is blank, the Oracle® Enterprise Session Border Controller will reference the associated SIP interface.
For an ingress SIP interface without a SIP profile or with a SIP profile where the forked CAC mode is blank, the Oracle® Enterprise Session Border Controller will not perform bandwidth sharing for forked calls.
- Save your work.
