Configuring Session Agents
You configure session agents with:
- payload type the
Oracle® Enterprise Session Border Controller wants to use for RFC 2833 packets while interworking 2833 and UII.
The default value for this attribute is 0. When this value is zero, the global rfc2833-payload configured in the h323-configuration element will be used instead. For SIP session agents, the payload defined in the SIP interface is used, if the SIP interface is configured with the preferred RFC 2833 mode.
- 2833 mode
A value of transparent or preferred for the session agent’s 2833 mode will override any configuration in the h323-stack configuration element.
To configure session agents:
