Enabling Payload Type Handling
You can configure H.323 session agents and H.323 interfaces (stacks) with an option that forces symmetric payload type use. For Payload Type Handling to work properly, you must set the following SIP interface and the global H.323 configuration parameters with these values:
- rfc2833-mode—Set this parameter to preferred; the default is transparent.
- rfc2833-payload—Set this parameter to the payload type you want forced for the remote endpoint. Your entry will be between
96 and
127, with
101 as the default.
To enable forced symmetric payload type handling for an H.323 session agent:
