PreviousNextJavaScript must be enabled to correctly display this content
Naming Codec Policies
The codec policy’s name is important not only because it uniquely identifies the policy, but because it is the name you will enter into your realm configuration’s
codec-policy parameter. It is important to apply the correct policy to the appropriate realm.
To set the codec policy’s name:
name—Set the name for this codec policy, and note it for future reference when you apply codec policies to realms. This parameter is required, and has no default.
