ACLI Configuration Instructions
The parameters that you can configure are name, allow-codecs, add-codecs-on-egress, order-codecs, and ptime. The following section provides brief explanations of how these parameters work, and how you configure each of them.
A single codec policy can be reused for any number of realms.To access the configuration parameters for codec policies:
