Realm-config Attribute
Use the following procedure to configure the realm-config attribute and enable session recording:
Access the
realm-config configuration element.
ORACLE# configure terminal ORACLE(configure)# media-manager ORACLE(media-manager)# realm-config ORACLE(realm-config)#
session-recording-server
— Enter the name of the session-recording server or the session-recording-group
in the realm associated with the session reporting client (Oracle® Enterprise Session Border Controller). Valid values are alpha-numeric
characters. Default is no value specified.
ACMEPACKET(realm-config)# session-recording-server <srs-name> or ACMEPACKET(realm-config)# session-recording-server SRG:<group-name>
The value for this attribute is the name you specified in the session-recording-server attribute. If specifying a session-recording-group, you must precede the group name with "SRG:". -
session-recording-required
— Enter whether you want a call to be accepted by the
Oracle® Enterprise Session Border Controller when recording is not available. The default value is
disabled.
Enabled — Restricts call sessions from being initiated when a recording server is not available.
Disabled (default) — Allows call sessions to initiate even when the recording server is not available.
Oracle recommends that the session-recording-required parameter remain disabled.
session-max-life-limit
— Enter the maximum interval in seconds before the SBC must terminate long
duration calls. The value supercedes the value of
in the
sip-interface and
sip-config configuration elements and is itself
superceded by the value of
in the
session-agent configuration element. The default value
is 0 (off/ignored).
test
- Type done to save your configuration.
