PreviousNextJavaScript must be enabled to correctly display this content
Consistent and Detailed Error Messages
Error message the system produces and displays in the ACLI are consistent and detailed. If your entry is invalid, the system tells you the range for a valid value.
ORACLE(system-config)# debug-timeout 99999
% Invalid Input
Value is not in the range 0..65535
