Tab Completion
Tab completion is available for every boolean, enumeration, and reference parameter. A reference parameter is one whose value references a value in another configuration. For example, a SIP interface configuration might reference the name parameter of a realm configuration; tab completion show you the names of the realms from which you can choose.
