Manual Trigger Confirmation
To confirm that a session agent has been sent offline:
Use the
show sipd endpoint-ip
command to confirm the session agent state.
ACMEPACKET# show sipd endpoint-ip 1016 User <sip:1016@172.18.1.80> Contact exp=3582 UA-Contact: <sip:1016@192.168.1.132:5060> UDP realm=access local=172.18.1.132:5060 UA=192.168.1.132:5060 SD-Contact: <sip:1016-o3badgbbnjcq5@172.18.2.80:5060> realm=core Call-ID: 1-7944@192.168.1.132’ SR=172.18.2.92 SA=172.18.2.93 Service-Route='<sip:test@s-cscf::5060;orig;lr>' ACMEPACKET# reset session-agent 172.18.2.92 Accepted Reset SA failover timer ACMEPACKET# show sipd endpoint-ip 1016 User <sip:1016@172.18.1.80> Contact <invalidated> exp=3572 UA-Contact: <sip:1016@192.168.1.132:5060> UDP realm=access local=172.18.1.80:5060 UA=192.168.1.132:5060 SD-Contact: <sip:1016-o3badgbbnjcq5@172.18.2.80:5060> realm=core Call-ID: 1-7944@192.168.1.132’ SR=172.18.2.92 (failed 2 seconds ago) SA=172.18.2.93 Service-Route='<sip:test@s-cscf::5060;orig;lr>' ACMEPACKET#
In the above ACLI example the first iteration of the show sip endpoint-ip command provides information for the in-service 172.18.2.92 session agent; the second command iteration displays information for the now out-of-service session agent.
