Manual Trigger Configuration
This section shows you how to enable the manual trigger for sending session agents out of service, and how to then use the trigger from the command line. This section also shows you how to verify that you have successfully put a session agent out of service.
To enable a SIP session agent to manually trigger it to go out of service:
