Number Translation Configuration
To create a translation rule:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the session router configuration elements.
ORACLE(configure)# session-router
Type
translation-rules
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# translation-rules ORACLE(translation-rules)#
From this point, you can configure translation rules parameters. To view all translation rules parameters, enter a ? at the system prompt. The following is an example of what a translation rule configuration might look like. Parameters not described in this section are omitted below.
translation-rules id addplus1 type add add-string +1 add-index 0 delete-string delete-index 0
