PreviousNextJavaScript must be enabled to correctly display this content
HA Node Connection Configuration
If you are using HA, you need to set the phy-interface configuration parameters described in this section to establish successful connections. These parameters are for rear and media interfaces.
To access the phy-interface menu in the ACLI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
system and press Enter to access the system-level configuration elements.
ORACLE(configure)# system
Type
phy-interface and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
