Setting SCTP Timers and Counters
Setting SCTP timers and counters is optional. All configurable timers and counters provide default values that conform to recommended values as specified in RFC 4960, Stream Control Transmission Protocol.
Management of Retransmission Timer, section 6.3 of RFC 4960 describes the calculation of a Retransmission Timeout (RTO) by the SCTP process. This calculation involves three SCTP protocol parameters: RTO.Initial, RTO.Min, and RTO.Max. Suggested SCTP Protocol Parameter Values section 15 of RFC 4960 lists recommended values for these parameters.
The following shows the equivalence of recommended values and ACLI defaults.
RTO.Initial = 3 seconds sctp-rto-initial = 3000 ms (default value)
RTO.Min = 1 second sctp-rto-min = 1000 ms (default value)
RTO.Max = 60 seconds sctp-rto-max = 60000 ms (default value)
Path Heartbeat, section 8.3 of RFC 4960 describes the calculation of a Heartbeat Interval by the SCTP process. This calculation involves the current calculated RTO and a single SCTP protocol parameter — HB.Interval.
The following shows the equivalence of recommended the value and ACLI default.
HB.Interval = 30 seconds sctp-hb-interval = 3000 ms (default value)
Acknowledgement on Reception of DATA Chunks, section 6.2 of RFC 4960 describes requirements for the timely processing and acknowledgement of DATA chunks. This section requires that received DATA chunks must be acknowledged within 500 milliseconds, and recommends that DATA chunks should be acknowledged with 200 milliseconds. The interval between DATA chunk reception and acknowledgement is specific by the ACLI sctp-sack-timeout parameter, which provides a default value of 200 milliseconds and a maximum value of 500 milliseconds.
Transmission of DATA Chunks, section 6.1 of RFC 4960 describes requirements for the transmission of DATA chunks. To avoid network congestion the RFC recommends a limitation on the volume of data transmitted at one time. The limitation is expressed in terms of DATA chunks, not in terms of SCTP packets.
The maximum number of DATA chunks that can be transmitted at one time is specified by the ACLI sctp-max-burst parameter, which provides a default value of 4 chunks, the limit recommended by the RFC.
