Configuring Session Agents
After configuring the realm, you identify adjacent SIP servers who will be accessed via the SCTP protocol.
From superuser mode, use the following command sequence to access session-agent configuration mode.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# session-agent ORACLE(session-agent)#
- Use the select command to access the target session-agent.
Use the
transport-method
parameter to select the layer 4 transport protocol.
Select staticSCTP for SCTP transport
ORACLE(session-agent)# transport-method staticSCTP ORACLE(session-agent)#
Set the
reuse-connections
parameter to none.
ORACLE(session-agent)# reuse-connections none ORACLE(session-agent)#
Use
done,
exit, and
verify-config to complete session agent configuration.
ORACLE(session-agent)# done ORACLE(session-router)# exit ORACLE(configure)# exit ORACLE# verify-config --------------------------------------------------------------------- Verification successful! No errors nor warnings in the configuration ORACLE#
- Repeat Steps 1 through 5 as necessary to configure additional session agents who will be accessed via SCTP transport.
