H.232 Service Modes Configuration
These are the ACLI parameters that you set:
isgateway Enable the stack to run as a gateway registration-ttl Number of seconds before the registration becomes invalid terminal-alias List of aliases for terminal auto-gk-discovery Enable automatic gatekeeper discovery multicast RAS multicast address gatekeeper Gatekeeper's address and port gk-identifier Gatekeeper's identifier h245-tunneling Enable H.245 Tunneling support prefixes List of supported prefixes process-registration Enable Registration Request processing allow-anonymous allowed requests from H.323 realm
To configure the service mode for the H.323 interface:
allow-anonymous—Enter the admission control of anonymous connections from an H.323 realm accepted and processed by this H.323 stack. The default value is
all. The valid values are:
all—Allow all anonymous connections
agents-only—Allow requests from session agents only
realm-prefix—Allow session agents and addresses matching the realm prefix
is-gateway—To use this interface as an H.323 gateway, leave this parameter set to
enabled, its default value. If you want to use this interface as an H.323 gatekeeper, set this parameter to
disabled. Valid values are:
enabled | disabled
- terminal-alias—Enter a list of one or more aliases that identify the H.323 interface. This value is either the gateway alias or the gatekeeper identifier, depending on the mode you configure for the interface. The aliases are set in the sourceInfo information element of outgoing ARQs.
