Configurable TCP Timers
You can configure your Oracle® Enterprise Session Border Controller to detect failed TCP connections more quickly so that data can be transmitted via an alternate connection before timers expire. Across all protocols, you can now control the following for TCP:
- Connection establishment
- Data retransmission
- Timer for idle connections
These capabilities all involve configuring an options parameter that appears in the network parameters configuration.
