Configuring TCP Connection Establishment
To establish connections, TCP uses a three-way handshake during which two peers exchange TCP SYN messages to request and confirm the active open connection. In attempting this connection, one peer retransmits the SYN messages for a defined period of time if it does not receive acknowledgement from the terminating peer. You can configure the amount of time in seconds between the retries as well as how long (in seconds) the peer will keep retransmitting the messages.
You set two new options in the network parameters configuration to specify these amounts of time: atcp-syn-rxmt-interval and atcp-syn-rxmt-maxtime.
Note that for all configured options, any values entered outside of the valid range are silently ignored during configuration and generate a log when you enter the activate command.
To configure TCP connection establishment:
