ACLI Show Commands for TDM
Time Division Multiplexing (TDM) uses a unique set of ACLI "show" commands to provide information about the TDM configuration and operational states.
The following TDM "show" commands work only on the Acme Packet 1100 and Acme Packet 3900 platforms with a TDM card installed. No other
Oracle® Enterprise Session Border Controller platforms recognize the TDM "show" commands.
| ACLI Command | Description of the Information Shown |
| show running-config tdm-config | The configuration object for TDM, which is located under System in the ACLI configuration tree |
| show running-config tdm-profile | The configuration object for the TDM profile, which is located under tdm-config in the ACLI configuration tree |
| show tdm spans | The state of spans, such as In Alarm, Down, and Active |
| show tdm span # | The state and configuration profile of a specified span |
| show tdm channels | The Context, Language, and State of the TDM channels |
| show tdm channel # | The profile of the specified channel |
| show tdm status | Thee TDM enablement status of State and Logging, plus the TDM profile |
| show tdm dialplan | The TDM dial plan |
