SNMPv3 Support
The Oracle® Enterprise Session Border Controller (E-SBC) supports SNMPv3, which provides the SNMP agent and SNMP Network Management System (NMS) with authentication, privacy, and access control during the delivery of secured traps. Currently, SNMPv3 traps are supported on the Net-Net ESD; SNMPv3 Get/Get-Bulk/Set actions are not supported at this time.
By default, the E-SBC supports SNMPv1v2. If you want to retain the existing SNMPv1v2 behavior, you do not need to update configuration. You can enable SNMPv3 at any time, at which point SNMPv1v2 configurations are ignored, and only SNMPv3 encrypted traps are sent to the associated external SNMP managers. Snmp-agent-mode, an attribute under system-config, allows you to select the mode that you want.
