Authentication and Privacy
SNMPv3 employs a User-Based Security Model (USM). The two protocols used for authentication and privacy are:
- Authentication—SHA
- Privacy—DES
Four parameters generate keys under the designated algorithm:
- SNMPEngineID—The unique identifier for the SNMP Engine. This value is a specially formatted string for use in the SNMP.
- User name—The user’s name as defined under snmp-user-entry.
- Authorization password—The authorization password configured under the snmp-user-entry configuration. This parameter is used to derive the authentication key.
- Privacy password—You set the privacy password in the snmp-user-entry configuration. It is used to derive the password key.
