Protocol-Specific Parameters and RTC
In addition, you should not change any of the parameters related to HA that are part of protocol or media management configurations that are used for protocol/media checkpointing. These are:
- SIP configuration
- red-max-trans
- red-sync-start-time
- red-sync-comp-time
- Media Manager configuration
- red-flow-port
- red-max-trans
