Setting the Response Code Block
To enable the SIP HMR enhancements, you need to set an option in SIP interface configuration that keeps the Oracle® Enterprise Session Border Controller from sending the response you designate.
Note that this example sets the dropResponse option to 699, where 699 is an arbitrary code used to later match the HMR.
To enable SIP response blocking for a SIP interface:
