Configuring MIME Support The find-replace-all action has been added to the header rules. Element rules support the find-replace-all action and the mime type. To set the header rule with the find-replace-all action: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type session-router and press Enter. ORACLE(configure)# session-router ORACLE(session-router)# Type sip-manipulation and press Enter. ORACLE(session-router)# sip-manipulation ORACLE(sip-manipulation)# Type header-rules and press Enter. ORACLE(sip-manipulation)# header-rules ORACLE(sip-header-rules)# action—Set the action parameter to find-replace-all if you want to enable SIP HMR MIME manipulation. Save and activate your configuration. To set the element rule with the find-replace-all action and MIME type: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type session-router and press Enter. ORACLE(configure)# session-router ORACLE(session-router)# Type sip-manipulation and press Enter. ORACLE(session-router)# sip-manipulation ORACLE(sip-manipulation)# Type header-rules and press Enter. ORACLE(sip-manipulation)# header-rules ORACLE(sip-header-rules)# Type element-rules and press Enter. ORACLE(sip-header-rules)# element-rules ORACLE(sip-element-rules)# action—Set the action parameter to find-replace-all if you want to enable SIP HMR MIME manipulation. type—Set the type parameter to mime if you want to enable SIP HMR MIME manipulation. Save and activate your configuration.
