PreviousNextJavaScript must be enabled to correctly display this content
Testing Pattern Rules
The
Oracle® Enterprise Session Border Controller it yields the results you require. This command is useful for testing the regex values that you devise because it will tell you whether that value is valid or not.
expression—Enter the regular expression that you want to test. If there is a match, then the
Oracle® Enterprise Session Border Controller will inform you of it; you will also be informed if there is no match.
The string against which the
Oracle® Enterprise Session Border Controller is matching is not the string parameter that you can use for this command; it is the string value of the regular expression you entered.
