If you are adding support for this feature to a pre-existing SIP configuration, then you must select (using the ACLI
select command) the configuration that you want to edit.
untrusted-conn-timeout—Enter the time in seconds that you want the
Oracle® Enterprise Session Border Controller to keep TCP and TLS connections open for untrusted endpoints. The default value is
0, which will not start the timer. The valid range is:
