HA Node Peer Configuration
To configure a Oracle® Enterprise Session Border Controller as an HA node peer:
From the redundancy menu, type
peers and press Enter.
ORACLE(system)# redundancy ORACLE(redundancy)# peers
state—Enable or disable HA for this
Oracle® Enterprise Session Border Controller. The default value is
enabled. The valid values are:
enabled | disabled
name—Set the name of the HA node peer as it appears in the target name boot parameter.
This is also the name of your system that appears in the system prompt. For example, in the system prompt ORACLE1#, ORACLE1 is the target name for that Oracle® Enterprise Session Border Controller.
type—These values refer to the primary and secondary utility addresses in the network interface configuration. To determine what utility address to use for configuration checkpointing, set the type of
Oracle® Enterprise Session Border Controller: primary or secondary.
You must change this field from unknown, its default. The valid values are:-
primary—Set this type if you want the Oracle® Enterprise Session Border Controller to use the primary utility address.
secondary—Set this type if you want the Oracle® Enterprise Session Border Controller to use the secondary utility address.
unknown—If you leave this parameter set to this default value, configuration checkpointing will not work.
