SAG Matching for LRT and ENUM
When this feature is enabled and a match is found, the Oracle® Enterprise Session Border Controller uses the matching SAG for routing. When there is no match for the SAG, the Oracle® Enterprise Session Border Controller processes the result as it would have if this feature had not been enabled: either matching to a session agent hostname, or performing a DNS query to resolve it.
Note that you set the state of this feature in the SIP configuration.
To configure a SAG for ENUM or LRT matching:
