Directed Egress Realm from LRT ENUM
A message can be sent into a specific egress realm identified in an ENUM query or LRT lookup. The egress realm is noted by a configurable parameter in the result URI. The Oracle® Enterprise Session Border Controller is configured with the name of this parameter, that indicates an egress realm name, and looks for it in the returned URI.
To configure the parameter name, the egress-realm-param option is added to the sip config and/or the h323 config using the following format:
egress-realm-param=<name>
Where <name> is the parameter name to extract the egress realm name from.
When the egress realm param is defined, the ENUM and LRT results will always be checked for the presence of the URI parameter. The sip config options will apply for received SIP requests. The h323 config option will apply for received H.323 messages.
For example, if egress-realm-param=egress is added to the sip config, a matching entry in the LRT that specifies the egress realm core will look like this:
<route> <user type="E164">+17815551212</user> <next type="regex">!^.*$!sip:\0@core.example.com;egress=core!</next> </route>
If the URI does not contain the parameter or the parameter identifies a realm that is not configured on the system, the egress realm that is normally applicable (from local policy, SIP-NAT, or session-agent data) will be used.
