LRT String Lookup Configuration
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
local-routing-config
and press Enter.
ORACLE(session-router)# local-routing-config ORACLE(local-routing-config)#
- string-lookup—Set this parameter to enabled for the Oracle® Enterprise Session Border Controller to perform LRT lookups on table keys of a string data type. Leave this parameter to its default as disabled to continue using E.164 type lookups.
- Save your work using the done command.
