HA Node Parameters
To establish a pair of Oracle® Enterprise Session Border Controllers as an HA node, you need to configure basic parameters that govern how the Oracle® Enterprise Session Border Controllers:
- Transition on switchover
- Share media and call state information
- Checkpoint configuration data
The following example shows what an HA configuration might look like in the ACLI.
redundancy-config state enabled log-level WARNING health-threshold 75 emergency-threshold 50 port 9090 advertisement-time 500 percent-drift 210 initial-time 1250 becoming-standby-time 45000 becoming-active-time 100
You need to configure the two Oracle® Enterprise Session Border Controllers to be HA node peers. To enable configuration checkpointing, you must to configure two peers in the ACLI, one for the primary and one for the secondary Oracle® Enterprise Session Border Controller. The HA node peers configuration also allows you to configure destinations for where to send health and state information. Unless you create Oracle® Enterprise Session Border Controller peers and destinations configurations, HA will not work properly.
peer name netnetsd1 state enabled type Primary destination address 169.254.1.1:9090 network-interface wancom1:0 peer name netnetsd2 state enabled type Secondary destination address 169.254.1.2:9090 network-interface wancom1:0
