Many-to-One Configuration
To configure many-to-one:
- For the backbone SIP NAT, ensure the home proxy address field is blank.
For the customer side SIP NAT:
Set the home address to match the home address of the customer.
Set the home proxy address to match the backbone SIP NAT home address.
Set route home proxy to forced.
The following table lists the field values you need to set to create a many-to-one SIP NAT bridge.
SIP NAT Entity Field Sample Values Backbone SIP NAT home address IPv4 address of the home realm. For example: 127.0.0.120
home proxy address IPv4 address of the home proxy from the perspective of the external realm. For a backbone SIP NAT, leave blank.
Customer SIP NAT home address 127.0.0.120 home proxy address 127.0.0.110 route home proxy forced
