Configuring the Realm
To configure the realm:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter to access the system-level configuration elements.
ORACLE(configure)# media-manager
Type
realm
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm ORACLE(realm)#
- If configuring an existing realm, enter the select command to select the realm.
early-media-allow—Enter the early media suppression rule for the realm. The valid values are:
none—No early media is allowed in either direction
both—Early media is allowed in both directions
reverse—Early media received by Oracle® Enterprise Session Border Controller in the reverse direction is allowed
There is no default value. If you leave this parameter blank, early media is allowed in either direction. You can use the following command to clear this parameter:
early-media-allow ()
Save and activate your configuration.
For example:
realm-config identifier access1 addr-prefix 192.168.1.0/24 network-interfaces media:0 mm-in-realm enabled mm-in-network enabled msm-release disabled qos-enable disabled max-bandwidth 0 max-latency 0 max-jitter 0 max-packet-loss 0 observ-window-size 0 parent-realm dns-realm media-policy in-translationid out-translationid class-profile average-rate-limit 0 access-control-trust-level none invalid-signal-threshold 0 maximum-signal-threshold 0 deny-period 30 early-media-allow none last-modified-date 2006-02-06 13:09:20
