PreviousNextJavaScript must be enabled to correctly display this content
Optional Virtual Machine (VM) Configuration
After creating and deploying a VM, you can use the
Oracle® Enterprise Session Border Controller ACLI to perform optional VM configuration. For example, you might designate a VM as a template for cloning.
