Format the Virtual Machine (VM) Hard Drive
You must format the VM hard drive upon installation.
Procedure
- Open the vSphere Client application to the Home page.
- Expand the left-hand tabs to display all VMs.
- Confirm that the target VM is powered on.
- Select the Console tab, and click anywhere in the window to identify that tab as the source of keyboard input.
- Logon in User mode.
- Use the enable command to enter Privileged mode.
- Use the format hard-drive command to format the VM hard drive.
- Use the reboot force command to reboot the VM and enable the disk changes.
