Trust Mode
To configure the trust mode:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-interface and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
From this point, you can configure SIP interface parameters. To view all sip-interface parameters, enter a ? at the system prompt.
- If configuring an existing interface, enter the select command to select the interface.
trust-mode—Select the trust mode for this SIP interface. The default value is
all. The valid values are:
all—Trust all previous and next hops except untrusted session agents
agents-only—Trust only trusted session agents
realm-prefix—Trusted only trusted session agents or address matching realm prefix
registered—Trust only trusted session agents or registered endpoints
none—Trust nothing
Save and activate your configuration.
The following example shows the trust-mode set to none. The remaining SIP interface options are omitted for brevity.
sip-interface state enabled realm-id access1 sip-port address 192.168.1.30 port 5060 transport-protocol UDP allow-anonymous all carriers proxy-mode Proxy redirect-action contact-mode maddr nat-traversal none nat-interval 30 registration-caching disabled min-reg-expire 300 registration-interval 3600 route-to-registrar disabled teluri-scheme disabled uri-fqdn-domain options trust-mode none
