Disabling the PPI to PAI Change
To disable the changing of PPI to PAI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-config and press Enter. The system prompt changes.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
From this point, you can configure SIP configuration parameters. To view all sip-config parameters, enter a ? at the system prompt.
- If configuring an existing SIP configuration, enter the select command to select it.
options—Enter
disable-ppi-to-pai. If adding to an existing list of options, use a preceding plus (+) sign.
options +disable-ppi-to-pai
- Save and activate your configuration.
