Local Policy Session Agent Matching Configuration
When you enable local policy session agent matching, remember that you can choose from five different ways to use the feature: all, realm, sub-realm, interface, and network.
This example shows you how to use the realm selection.
To enable local policy session agent matching using the realm method:
- Unordered—Meaning that the endpoint can deliver data within regard for their stream sequence number
You set this preference in the network parameters configuration.
