SCTP Delivery Mode Configuration
To set the SCTP delivery mode:
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal ACMEPACKET(configure)#
Type
system and press Enter.
ACMEPACKET(configure)# system ACMEPACKET(system)#
Type
network-parameters and press Enter.
ACMEPACKET(system)# network-parameters ACMEPACKET(network-parameters)#
- sctp-send-mode—Leave this parameter set to its default (unordered) so data delivery can occur without regard to stream sequence numbering. If data delivery must follow stream sequence number, change this parameter to ordered.
- Save and activate your configuration.
