About Wildcarding
The Oracle® Enterprise Session Border Controller supports wildcarding the event type in the subscribe-event configuration. To wildcard the value, you enter an asterisk (*) for the event-type parameter instead of typing in the name of an actual event type.
When you wildcard this value, the Oracle® Enterprise Session Border Controller applies the subscription limitations you set across all event types. Or, if you have entered multiple subscribe-event configurations, the Oracle® Enterprise Session Border Controller applies the wildcard limits across the event types for which you have not set limits.
Consider the following example of a configured enforcement profile with a wildcarded subscribe-event configuration:
enforcement-profile
name rulefour
allowed-methods
sdp-address-check disabled
subscribe-event
event-type *
max-subscriptions 1
subscribe-event
event-type xyz
max-subscriptions 0
last-modified-by admin@console
last-modified-date 2008-11-11 12:49:27
In this example, the enforcement profile allows all subscriptions that are event type xyz for a user. But it allows only one maximum for every other subscription event type.
