HA Backout Procedure
If you reach the point in your upgrade procedure where you have upgraded both Oracle® Enterprise Session Border Controllers in the HA node to a later release that you decide you no longer want to use, you can fall back to a previous release. This section shows you how to fall back to an older image with both systems in your HA node upgraded.
In the descriptions and processes outlined below, Oracle® Enterprise Session Border Controller1 is the active system and Oracle® Enterprise Session Border Controller2 is the standby system. The procedure uses these designations because when you have completed upgrade process specific to these releases, Oracle® Enterprise Session Border Controller1 is the active system.
To backout to a previous (older) release with the both Oracle® Enterprise Session Border Controllers in the HA node upgraded:
